To Do Summary Zone
The To Do Summary Zone has several purposes:
• It presents a summary of the To Do entries that have been assigned to you and are Being Worked On.
• The colored "age bars" highlight the age of the To Do entries. The colors red, yellow and green are used to highlight the relative number of old, middle-aged and new To Do entries. The age associated with each of these colors is user-configurable. Note, you can hover the cursor over an "age bar" to see the number of To Do entries.
• If you click on the To Do Type description or on an "age bar", you'll be transferred to the To Do List transaction where these To Do entries will be displayed. From this page, you can drill down to the specific entries.
Note:Time saver! After you drill down on entry from the To Do List page, if you have the Current To Do zone configured in the dashboard, you can use the Previous To Do and Next To Do buttons in the zone to scroll through additional To Do list entries without returning to the To Do List page.
