Report History - Main
This page allows you to view a report stored in your third party reporting tool's report repository, if supported. Navigate to this page using Menu > Tools > Report History.
Description of Page
The top part of the page shows the Report Code, Description and Long Description for the selected report.
To select a report, search by either Report Code or Description and click the adjacent search button. The reports matching your search criteria are displayed. Choose the desired report from the selection list.
Note:Displaying Report History. When you choose a report, the system needs to interface with your reporting software to display a list of historical occurrences of this report.
