Outbound Message - Response
Use this page to display the XML response. Open this page using Menu > Integration > Outbound Message and then navigate to the Response tab.
Description of Page
The XML Response and optionally the XML Raw Response is displayed.
XML Response displays the response data from the system called by the real-time message. If a response XSL is defined on the external system / outbound message type record linked to this outbound message, a transform is performed and the XML Raw Response displays the original, unchanged response.
