Defining Checklist Types
This portal is used to maintain checklist types. A checklist type defines the maintenance object it is applicable to, the impact it should have with its applicable maintenance object, and the statuses it should impact.
You can access this portal from Admin, select C, then select Checklist Type.
The following zones may appear as part of the portals Main tab page.
• Checklist Type List. This zone lists all permit classes. Broadcast a record to display the details for the selected record.
• Checklist Type. This zone provides information about the selected checklist type, including defaulted checklist items and processing constraints.
Parent topic
