Defining Compatible Unit Categories
The Compatible Unit Category portal is used to display and maintain compatible unit categories.
You can access the portal from Admin, select C, then select CU Category.
CU Category List: This zone lists all compatible unit category records. Broadcast a record to display the details of the selected record.
CU Category: This zone provides information about the selected compatible unit category.
