Defining Functional Process Types
The Functional Process Type portal is used to display and maintain functional process types.
You can access the portal from Admin, select F, then select Functional Process Type.
Functional Process Type List: This zone lists all functional process type records. Broadcast a record to display the details of the selected record.
Functional Process Type: This zone provides general information about the selected functional process type.
Refer to Understanding Functional Process Types for more information.
