Defining Miscellaneous Resource
This portal is used to maintain equipment resources. Equipment is a resource required to work an activity.
You can access this portal from Admin, select M, then select Miscellaneous Resource. The user is brought to a query portal with options for searching for a miscellaneous resource. Once the resource has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The following zone may appear as part of the portals Main tab page.
• Other Resource. This zone provides information about the selected other resource, including accounting information.
• Unit Price. This zone enables a unit price and effective date to be defined for the other resource.
• Notes. This zone displays any notes associated with this other resource record.
• Attachments. This zone enables users to manage all types of attachments for the resource record.
Parent topic
