Defining Property Units
The Property Unit portal is used to display and maintain property units.
You can access the portal from Admin, select P, then select Property Unit.
• Property Unit List: This zone lists all property unit records. Broadcast a record to display the details of the selected record.
• Property Unit: This zone provides information about the selected property unit.
