Defining Questions
The Question portal is used to display and maintain condition assessment questions.
You can access the portal from Admin, select Q, then select Question. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Question: This zone provides information on question and answers for conditional assessments.
Service History List: This zone displays a list of associated service history types.
