Asset Synchronization Batch Processes
Inbound synchronization can be performed for an initial synchronization or for delta updates and changes.
Synchronization request records are processed by the synch request monitor batch process, and it is at that time that the actual outbound message is prepared and sent to the external system.
No batch needs to run explicitly for outbound synchronization as the interface dynamically updates the GIS system.
The following sections describe the background processes involved in asset synchronization from the GIS system.
Before initiating the inbound synchronization, make sure that configuration is done in Master Data Synchronization master configuration record. Refer to Understanding Data Synchronization for more information.
Initial Synchronization
The following batch processes need to be run in sequence to complete the initial load of all eligible assets from the GIS system.
The system keeps track of the status of the initial conversion process in the One-time Data Conversion field of the Esri WAM Integration master configuration record. Until the process is complete, the field shows Convert all Esri data.
Step
Batch Code
Description
Additional Parameters (if any)
1
W1–GISID
Retrieve GIS ID’s
2
W1–PRGIS
Process GIS Data
3
W1-CMSYN
Composite Sync Request
State: PENDING
BO: W1-CompositeSyncReqGISAsset
4
F1-SYSRQ
Sync Request Monitor (Deferred)
State: PENDING
BO: W1-InitialSyncRequestLocation
5
F1-SAKRQ
Sync Request Allocate Keys Monitor
State: DATA-TRANSFD
6
W1-SIKSP
Initial Sync Request - Resolve Keys Loc
State: KEY-ALLOCATD
7
W1-SILSP
Initial Sync Request - Load Data Location
State: KEYS-RESOLVD
8
W1-SILDD
Initial Sync Request - Loaded
State: LOADED
9
F1-SYSRQ
State: PENDING
BO: W1-InitialSyncRequestAsset
10
F1-SAKRQ
State: DATA-TRANSFD
11
W1-SIKAS
Initial Sync Request - Resolve Keys Asset
State: KEY-ALLOCATD
12
W1-SILAS
Initial Sync Request - Load Data Asset
State: KEYS-RESOLVD
13
W1-SILDD
State: LOADED
14
W1-DELVR
GIS Delete Version
Ongoing Synchronization
After the initial conversion is complete, the following batch processes need to be run periodically and in the specified sequence to uptake ongoing delta changes to eligible assets from the GIS system.
Step
Batch Code
Description
1
W1–GISID
Retrieve GIS ID’s
2
W1–PRGIS
Process GIS Data
3
W1-CMSYN
State: PENDING
4
W1-SIOPE
Ongoing Sync Request - Pending
State: PENDING
BO: W1-OngoingSyncRequestLocation
5
W1-SIOPE
State: PENDING
BO: W1-OngoingSyncRequestAsset
6
W1-DELVR
GIS Delete Version
