360 Degree Search
The 306 Degree Search portal is used to search for assets, components, specifications, location, and contacts.
You can access the portal from Menu, and then select 360 Degree Search. You are brought to a query portal with options for searching for a specific object record.
From the search results list, you can navigate to the selected portal to view data for the object.
This feature is only used in Oracle Utilities Operational Device Management.
