Maintaining Manufacturers
The Manufacturer portal is used to display and maintain a manufacturer record.
You can access the portal from Menu, select Asset Management, then select Manufacturer. You are brought to a query portal with options for searching for a specific manufacturer. Once a manufacturer has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Manufacturer: This zone displays information about the manufacturer.
Manufacturer Specifications: This zone lists the specifications associated with the manufacturer record.
