Maintaining Material Dispositions
The Material Disposition portal is used to display and maintain material disposition records.
You can access the portal from Menu, select Work Management, then select Material Disposition. You are brought to a query portal with options for searching for a material disposition record. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Material Disposition: This zone displays asset disposition information.
