Maintaining Stock Transfers
The Stock Transfer portal is used to display and maintain a stock transfer records.
You can access the portal from Menu, select Inventory, then select Stock Transfer. You are brought to a query portal with options for searching for a specific stock transfer record. Once a stock transfer record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Stock Transfer: This zone displays information about the selected stock transfer.
Stock Transfer Quick Add: This zone enables the addition of stock to the transfer request.
The following zones may appear as part of the portal’s Stock Transfer Receipt tab page:
Stock Transfer Receipt Header: This zone displays general receipt header information.
