Maintaining Work Designs
The Work Design portal is used to display and maintain a work design record.
You can access the portal from Menu, select Construction Work Management, then select Work Design. You are brought to a query portal with options for searching for a specific record. Once a work design has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Work Design: This zone displays information about the work design, such as required by date, originating designer, and handling details for the design elements.
• Design Elements: This zone lists the design elements associated with the work design record.
• Contractor Bids: This zone lists contractor bids associated with the work design record.
• Construction Work Order: This zone displays a hierarchical view of the construction work orders and activities created from the work design.
• Attachments: This zone enables users to manage all types of attachments for the work design record.
• Work Design Notes: This zone displays any note information associated with the work design record.
• Contact Relationship: This zone displays any contact information associated with the work design record.
• Communication Log: This zone displays any communications associated with the work design record.
The following zones may appear as part of the portal's Estimate tab page:
• Work Design Estimate: This zone displays all cost associated with the work design.
The following zones may appear as part of the portal's Compatible Units tab page:
• Work Design — CU Assignment: This zone enables users to search for and then add compatible units to multiple design elements.
The following zones may appear as part of the portal's Log tab page:
• Work Design Log: This zone displays log details for the work design.
• Approval Request History: This zone lists the approval history for the current work design.
