Reorder Review Mass Approval
The Reorder Review Mass Approval portal is used to search for reorder review records ready for approval.
You can access the portal from Menu, select Inventory, and then select Reorder Review Mass Approval. You are brought directly to the Reorder Review Mass Approval page.
The portal's Main tab page enables users to filter search criteria by Purchase Commodity, Buyer, or Create Date Range. User can select any number of reorder review records and click Approve to mass approve the records.
