Work Designs
Work designs are used for construction projects to produce one or many construction estimates with resource requirements. Designs can ensure that all necessary requirements are accounted for before the actual work begins. A single project can have multiple versions so that you can compare different approaches to the project and how they might affect costs. Resources included on the original work design are carried over to each new version where users can make the needed adjustments.
Design Elements
Design elements “build” a work design by indicating the compatible units and other resources that are needed for one construction location where one or many assets are planned.
