Installing the Script
The Conversion Setup Utility is provided to set up conversion schemas. It can be run from UNIX or Windows machines that has the following installed:
• Either Oracle 19c or Oracle 19c Client as long as can connect to the database
• JDK 1.8
The Conversion folder includes the conversion setup utilities - ConvSetup.tar, scripts to create the users, and jarfiles.
ConversionSetup Java Usage
usage
com.oracle.ouaf.oem.conversion.ConversionSetup
-a, --apply
Apply Conversion setup on Staging Schema. '-s' is mandatory if '-a' is passed
-d,--dbConnString <arg>
DB connection string: Any "jdbc:oracle:thin"supported format [example: HOST:PORT/SID | HOST:PORT:SERVICE | <TNSSTRING>]
-o,--output <arg>
Output Directory for the generated files. Directory will be created if it doesn't already exist.
-p,--prodSchema <arg>
Primary/Production Schema and credentials to connect: CIS_ADMIN,CIS_PSWD. [example: CISADM,CISADM]
-r,--rollback
Revert Conversion setup on Staging Schema. '-s' is mandatory if '-r' is passed
-s,--stgSchema <arg>
Staging Schema and Staging users:STG_ADMIN,STG_PSWD,STG_RW_USER [example: STGADM,STGADM,STGUSER]
This section of the document describes how to create the databases for the conversion tool kit.
