Upgrade Paths
The following upgrade paths are supported from:
• V2.3.0.0.0 to V2.4.0.1.1
• V2.4.0.0.0 to V2.4.0.1.1
Note: Before you can upgrade you must have a prior version installed. Otherwise, you should follow the procedures described in the Initial Installation Procedure section of the Oracle Utilities Operational Device Management Installation Guide.
