Account Information
The Account Information dimension contains shared data elements about a customer's account.
| Data Element | Description |
| Active electric meters |
The number of electric meters associated with a service point. Type: Attribute |
| Active gas meters |
The number of gas meters associated with a service point. Type: Attribute |
| Active rate codes |
A list of rate codes associated with a customer's utility accounts. Type: Attribute |
| Has AMI meter |
An indicator of whether a resident has an AMI meter. Type: Attribute |
| Has active account |
An indicator of whether a customer is an active customer at a utility. It is recommended that you use this attribute as a common filter in your dashboards to ensure you are viewing customers who are active. Type: Attribute |
