Use Pre-Built Dashboards
To make things easier for you, Opower Analytics Visualization comes with a set of pre-built dashboards that you can update and customize for your own purposes. This saves you the time it takes to create brand new visualizations.
To access a pre-built dashboard:
  1. Click the accordion icon in the upper left corner of the screen.
  2. Click Catalog, and then click the Shared Folders tab.
  3. Click one of the folders that displays. See Pre-Built Dashboards for more information about the available dashboards and what they contain.
To customize a prebuilt dashboard:
If you want to customize any of the pre-built dashboards, you must first create a copy and store it in a different folder. This is because any customizations made to the dashboards will be lost when the application is patched or upgraded.
  2. Click Catalog, and then click Shared Folders.
  3. Click one of the workbook folders, and then select one of the dashboards to open it.
  4. Click Save As.
  5. In the Save Workbook dialog, edit the Location section to move the workbook to a new folder, and click Save.
  6. Customize the dashboard to meet your needs.
