Handling Updates
Consumers of the Web Audit Customer Answers and Questions extract should consider the
unique key for each row to be a combination of utility_customer_id,
premise_id, and question_name. This means that any
row with a previously unseen combination of the above should be entered in the target
system as a new record. Any row which matches an existing combination of the above
should overwrite the existing values in user_input_answer or the
selected_answer_option for the given
utility_customer_id/ premise_id/question_name
combination.
