11 Tip Actions Extract (Incremental)
The Tip Actions extract contains responses to tips on the Energy Efficiency web portal that have an action date within a specified date range. It is available in Inside Opower or as a standard recurring extract if you Contact Your Delivery Team.
| Column | Description |
| utility_customer_id |
The customer identifier that is used on customer communications. This
is usually the same value as the Example: 1234-1234-1234-1234 Field Size: 40. Can Be Empty?: No. |
| tip_name |
Oracle Utilities Opower tip name. Example: tip001_buy_energy_star. Field Size: 64. Can Be Empty?: No. |
| action_date |
Date of action. Field Size: 10. Can Be Empty?: No. |
| action_type |
Type of action. Allowed Values:
Field Size: 9. Can Be Empty?: No. |
