14 Web Logins Extract (Incremental)
The Web Logins extract contains a list of customer logins to the Energy Efficiency Web Portal - Classic within a specified date range. It is available as a standard recurring extract if you Contact Your Delivery Team.
| Column | Description |
| utility_customer_id |
The customer identifier that is used on customer communications. This
is usually the same value as the Example: 1234-1234-1234-1234 Field Size: 40. Can Be Empty?: No. |
| login_time |
Date and time of login. Field Size: 19. Can Be Empty?: No. |
