Unsubscribe Data Integration Process
Integration of your unsubscribe data into the Oracle Utilities Opower platform generally involves the following phases: sample historical file integration and incremental file integration. In each phase, your Delivery Team will work with you to integrate, validate, and approve each of these files. The files will contain the same columns, and will follow the same formatting and naming standards. The files will only differ in the number of customers included and the periods of time they cover. See Data Transfer Process Overview for more information about each phase of the process.
