File Transfer Limits
There is a limit to the file size and file count that the Oracle Utilities Opower data ingest system can process in a day. The table below indicates the limits for uncompressed data files.
Given the minimum setup and break down time that the data transfer jobs require to ingest data, it is recommended that you send a small number of large files to Oracle Utilities Opower rather than a large number of small files. A small number of large files can be processed faster than a large number of small ones.
File Size (Gb) Daily File Count Limit
1 45
2 20
3 15
4 10
As an example, the first row indicates that if your files are 1 gigabyte in size, then you can transfer a maximum of 45 such files in a day to Oracle Utilities Opower. The second row indicates that if your files are 2 gigabytes in size, then you can transfer a maximum of 20 such files in a day.
