Line Item Fields
The line item fields include data related to the specific lines and charges that appear on a customer's bill.
Field Description
bill_id
The primary utility identifier of a bill. This is used to disambiguate bills.
Type: VARCHAR(40)
Can Be Empty?: No. Primary Key.
Note: This field is not required if you are sending your billing data in a single file to Oracle Utilities. See Billing Data File Specifications for more information.
bill_segment_id
The unique identifier of the bill segment in the source system.
Type: VARCHAR(40)
calculation_header_sequence_number
The identifier for the calculation header within the bill segment. This identifier will typically be 1 unless multiple versions of the rate were in effect during the bill period.
Type: VARCHAR(40)
bill_line_sequence
A system-assigned unique identifier of the bill line item.
Type: VARCHAR(40)
calculated_amount
The calculated amount associated with the bill line item.
Type: DECIMAL(15,2). See Supported Decimal Formats for details.
Can Be Empty?: No.
description_on_bill
The information about the bill line that appears on the customer's bill.
Type: VARCHAR(255)
Can Be Empty?: No.
print
A flag that indicates whether information about this line will print on the customer's bill.
Allowed Values:
  • Y
    Display information on the customer's bill.
  • N
    Do not display information on the customer's bill.
Type: BOOLEAN. See Supported Boolean Formats for more information.
Can Be Empty?: Yes. When empty, this defaults to N.
bill_line_item_type
The category of the line item charge, such as a tax, fee, distribution charge, transmission charge, etc. The categories are defined by the utility. Oracle Utilities Opower will map them to internal categories.
Type: VARCHAR(30)
Can Be Empty?: Yes, but preferred to not be empty.
bill_line_item_unit_of_measure
The unit of measure (UOM) of the line item. There is also a UOM at the segment read for cases when a measured quantity is different than billed quantity.
For example, gas prices are expressed in an amount per therm, but gas meters are expressed in volume.
Type: VARCHAR(30)
Can Be Empty?: Yes.
bill_line_item_time_of_use
The time-of-use code of the service quantity priced on the calculation line. There will be one bill line item per TOU period.
Type: VARCHAR(40)
Can Be Empty?: Yes.
bill_line_item_service_quantity_identifier
The service quantity priced on the calculation line. This value is used to further distinguish between measured quantities that have identical UOM/TOU combinations. For example, this value could distinguish between On-Peak KWH generation and On-Peak KWH consumption for solar customers.
Type: VARCHAR(255)
Can Be Empty?: Yes.
billable_service_quantity
The service quantity priced on the calculation line. For example, On-Peak KWH is 159 kWh.
Type: DECIMAL(18,6). See Supported Decimal Formats for details.
Can Be Empty?: Yes.
base_amount
A value used by calculation lines (such as taxes) that are dependent on other values (such as volumetric charges). The Base Amount shows the total amount derived from the cross-referenced line(s) that the current line then used to calculate its billed amount.
Can Be Empty?: Yes.
exempt_amount
The amount of the calculated charge that the customer doesn't have to pay because they are tax exempt.
Can Be Empty?: Yes.
measures_peak_quantity
A flag that indicates if the UOM priced on the calculation line is used to measure a peak quantity.
Allowed Values:
  • Y
    Line measures peak quantity.
  • N
    (Default) Line does not measure peak quantity.
Can Be Empty?: Yes.
bill_line_item_updated_at
The date at which the record was updated in the source system. If left blank, the field does not store any data.
Type: DATETIME. See Date and Time Handling for details.
Can Be Empty?: Yes.
