Rate Engine Plus Rate Eligibility
Customer rate eligibility information is required if Oracle Utilities Opower Rate Analysis features are enabled for the utility. Rate eligibility information is used to determine the rate plans for which customers may be eligible. Eligible rate plans are then displayed in rate analysis features, such as the Rate Comparison. If required, Oracle Utilities will work with the utility to collect eligibility information.
