Service Agreement Rate Fields
The service agreement rate data entity contains information about the rate used to calculate a service agreement's bill amounts. Rates will be associated with the service agreement on the same line of the file and should be the current rate code in effect for the service agreement at the time of the extract. Oracle Utilities Opower will keep a history of rate codes that were sent. It is assumed that a new effective_date is a new entry in the history. Having the same value as a previously-sent effective_date is treated as a correction.
Although the fields below are described separately from the other fields in the Main Account Data File, they must be included in the same file as the other fields, with all columns included in every row. See Account Data File Specifications for more information.
Field Description
sa_rate_code
The rate used to calculate the service agreement’s bill segments. Multiple rows will only exist if the service agreement’s rate changes over time.
Type: VARCHAR(40)
Can Be Empty?: No.
effective_datetime
The date the rate becomes effective.
Type: DATETIME. See Date and Time Handling for details.
Can Be Empty?: No.
service_agreement_rate_updated_at
The date at which the record was updated in the source system. If left blank, the field does not store any data.
Can Be Empty?: Yes.
Example Data
For example, consider the following sequence of files sent to Oracle Utilities Opower and the resulting operational state.
File service_agreement_id other fields sa_rate_code effective_date Result
1 1234567890 ... ER-BASIC 2018-01-01 00:00:00 Inserted as first entry, effective from 2018-01-01 00:00:00 until the end of time.
2 1234567890 ... ER-DMINU 2018-05-01 00:00:00 Inserted as second entry, effective from 2018-01-01 00:00:00 until the end of time. Previous entry now made to end as of 2018-04-30 23:59:59.
3 1234567890 ... ER_BASIC 2018-05-01 00:00:00 Correction of data in previous file #2, and sa_rate_code updated.
4 1234567890 ... ERES1 2018-06-01 00:00:00 Inserted as third entry, effective from 2018-01-06 00:00:00 until the end of time. Previous entry now made to end as of 2018-05-31 23:59:59.
