Service Point Fields
The billing data service point fields capture details such as the service point location, meter type, and any applicable parcel data.
Each table row represents a column in the data file. The header row of the data file must contain all table "Column Name" values, even if all values in those columns are blank. The columns must appear from left to right in the order in which they appear in the table and be separated by tab characters. See Legacy Billing Data File Specifications for more information.
| Column Name | Description |
| service_point_id |
Utility’s unique identifier for the service point. A service point identifies an unchanging device location where service is delivered. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_house_number |
The house number portion of the street address. For example, 123 for 123 Main Street. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_street_name |
Street name. If applicable in your service territory, this field should include predirection (beginning of string), street suffix, or postdirection (end of string) as appropriate. For example, W 24th St NE. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_unit |
The unit number. For example, 2A for Apartment 2A. Note: This field is required for multi-unit premises.If possible, do not supply data such as “Third pole” that indicates where the meter is located. Type: STRING Can Be Empty?: Yes. Default: Null. |
| service_city |
The city in which the service point is located. Do not include the state. For example, Richmond. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_state |
The 2-character state code where the service point is located. For example, VA for Virginia. Type: STRING (2 characters) Can Be Empty?: No. Default: Not applicable. |
| service_zip_code |
5-digit zip or 9-digits of zip+4. For example, 22209 or 22209-1234. Zip+4 is requested if available to help geocode service point addresses. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_premise |
A named location, usually a building or collection of buildings with a common name. Type: STRING Can Be Empty?: Yes. Default: Not applicable. |
| service_street_number |
The house number portion of the street address excluding floor, apartment, flat, or suite number/indicator. For example, 123 for 123 Main Street.For example, 123 for 123 Main Street, Apartment A. Type: STRING Can Be Empty?: Yes. Default: Not applicable. |
| service_street |
Street name of the service address - includes predirection (left), street suffix, or postdirection (right) as appropriate. For example, 24th St West. Street name of the service address - includes street type and suffix as appropriate. For example, 24th St West. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_subpremise |
Apartment, flat, or floor # of the service address. For example, Flat 2 or 5th Floor. Type: STRING Can Be Empty?: Yes. Default: Null. |
| service_locality |
Post town / city / locality of the service address. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| service_sublocality |
Sublocality is required if the street name is not unique within the post town area. Include suburb in this field if it is a customary component of this address. Type: STRING Can Be Empty?: Yes. Default: Not applicable. |
| service_admin_area_1 |
Include the county of the service point, if available. Abbreviated province for the service address. For example, NS. Abbreviated state or territory for the service address. Province or territory abbreviation of the service point. Type: STRING Can Be Empty?: Yes. Default: Not applicable. |
| service_postal_code |
5-7 character postcode. For example, M1 1AA, DN55 1PT of the service address. Six-character postal code for the service address. For example, B3J 2Y3. 4-digit numeric postal code. Type: STRING Can Be Empty?: No. Default: Not applicable. |
| meter_type |
The fuel type reported by the meter. Allowed Values:
Type: STRING Can Be Empty?: Yes. Default: E |
| meter_units |
The unit of energy used to represent usage values. Allowed Values:
Only one In addition, it is not possible to change the
If you need support to address either of these restrictions, contact your Delivery Team. Type: STRING Can Be Empty?: Yes. Default: K |
| voltage_class |
A grouping of commercial customers based on how they receive electricity. Determines what discounts are earned by a commercial customer. Allowed Values:
| latitude |
Latitude of the service address, expressed as a decimal number of degrees between -90 and 90, no directional indicators. Any latitude data should be rooftop or better. If less specific than rooftop, leave as null (empty/blank). If no latitude value is available, leave this empty instead of supplying a value of 0. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| longitude |
Longitude of the service address, expressed as a decimal number of degrees between -180 and 180, no directional indicators. Any longitude data should be rooftop or better. If less specific than rooftop, leave as null (empty/blank). If no longitude value is available, leave this empty instead of supplying a value of 0. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| dwelling_type |
An indication of the type of dwelling in which a customer lives. Allowed Values:
| bldg_sq_foot |
Square footage of the living area of the building. This generally does not include the garage, unfinished basement, or porch. This information is used to select neighbors or similar homes for the normative comparison. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| parcel_sq_foot |
Square footage of the parcel lot. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| year_built |
Year the structure was built. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| total_rooms |
Total number of rooms in the structure. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| assess_value |
Either the assessed value of the property, or a number or letter representing a range for the value. A blank field indicates that the assessed value is unknown. Type: NUMBER Can Be Empty?: Yes. Default: Null. |
| heat_type |
The heat type used by the customer. Allowed Values:
| photovoltaic |
A flag to indicate whether the customer generates photovoltaic or solar power. Allowed Values:
| pool |
A flag to indicate whether the customer has a pool. Allowed Values:
| air_cond |
A flag to indicate whether the customer has air conditioning. Allowed Values:
| bedrooms |
Number of bedrooms in the structure. This can be used in place of
| amperage |
The amperage value, expressed as a floating point number. For example, 1.24. Type: NUMBER Can Be Empty?: Yes. Default: Not applicable. |
