Service Point Fields
The service point entity includes fields related to the device location where service is delivered.
Although the fields below are described separately from the other fields in the premise data file, any premise data that you send to Oracle Utilities must be included in the same file, with all columns included in every row of the file. See Premise Data File Specifications for more information.
Field Description
service_point_id
The unique service point identifier in a utility's Customer Information System or other system of record. A service point identifies an unchanging device location where service is delivered.
Type: VARCHAR(40)
Can Be Empty?: No. Primary Key.
service_point_name
The name of the service point as displayed in the utility Customer Information System or other system of record, if applicable.
Type: VARCHAR(40)
Can Be Empty?: Yes.
service_point_type_description
A short description of the service point code.
Example Values: Electric Commercial, Gas Residential, Water Industrial
Type: VARCHAR(100)
Can Be Empty?: Yes.
service_point_type_category
A flag that indicates the type of device installed at service points of this type.
Allowed Values:
  • D1MT
    Indicates that a single meter can be installed at service points of this type.
  • D1IT
    Indicates that a single "badged" item can be installed at service points of this type. A badged item refers to objects like street lamps that have a unique ID.
  • D1MI
    Indicates that one or more "unbadged" items can be installed at service points of this type.
Type: VARCHAR(4)
Can Be Empty?: No.
service_point_type_code
The service type provided by service points of this type.
Allowed Values:
  • E
    Electric
  • G
    Gas
  • W
    Water
  • M
    Miscellaneous
  • WW
    Waste water
  • O
    Other
Type: VARCHAR(2)
Can Be Empty?: No.
service_point_start_datetime
The date on which the service agreement was associated with the service point.
Type: DATETIME. See Date and Time Handling for details.
Can Be Empty?: Yes.
This field should only be populated if it will be used in the Oracle Utilities DataRaker solution. Otherwise it will be ignored.
service_point_end_datetime
The date on which the service agreement was disassociated from the service point.
Can Be Empty?: Yes.
service_cycle_code
The service point’s measurement cycle. A measurement cycle can define the schedule for manual meter reading of devices at service points, or it can define when to calculate bill determinants for usage subscriptions associated to service points in the cycle.
Example Values: CYCLE01, CYCLE02
Type: VARCHAR(30)
Can Be Empty?: Yes.
service_cycle_description
The description for the service cycle code.
Example Values: Read Cycle 01, Read Cycle 02
Type: VARCHAR(300)
Can Be Empty?: Yes.
service_route_code
The route used to collect measurements.
Example Values: ROUTE-100, ROUTE-110
Type: VARCHAR(30)
Can Be Empty?: Yes.
service_route_description
The description for the route code.
Example Values: Route 100, Route 110
Type: VARCHAR(100)
Can Be Empty?: Yes.
facility_level_1
The substation network node level closest to the service point.
Type: VARCHAR(30)
Can Be Empty?: Yes.
facility_level_2
The feeder or distribution circuits that carry power from the substations to the transformers closest to the service point.
Type: VARCHAR(30)
Can Be Empty?: Yes.
facility_level_3
The step down transformer closest to the premise.
Type: VARCHAR(30)
Can Be Empty?: Yes.
life_support_sensitive_load_code
A Boolean value that identifies whether the premise has life support or sensitive load equipment.
Allowed Values:
  • Y
    Premise has life support equipment.
  • N
    Premise does not have life support equipment.
Type: BOOLEAN. See Supported Boolean Formats for more information.
Can Be Empty?: Yes. If left empty, this field defaults to N.
status_code
The current status of the service point.
Allowed Values: ACTIVE, INACTIVE
Type: VARCHAR(12)
Can Be Empty?: Yes.
source_status_code
A status code that identifies if the service point is connected or disconnected to the distribution network.
Example Values:
  • D1CN
    Service point is connected to the distribution network.
  • D1DC
    Service point is disconnected from the distribution network.
Type: VARCHAR(30)
Can Be Empty?: Yes.
disconnect_location
A code that identifies whether the service is disconnected at the device or at a source such as a service pole.
Example Values:
  • D1DV
    Service is disconnected at the device.
  • D1SR
    Service is disconnected at another source.
Type: VARCHAR(30)
Can Be Empty?: Yes.
remote_disconnect
A Boolean value to indicate whether to remotely disconnect a customer's service point from receiving service.
Can Be Empty?: Yes. If left empty, this field defaults to FALSE.
service_point_time_zone
The timezone of the service point. The value provided must conform to the specification in the Internet Assigned Numbers Authority database.
Type: VARCHAR(32)
Can Be Empty?: No.
Example Values:
  • Central: America/Chicago, US/Central
  • Eastern: America/New_York, US/Eastern
  • Pacific: America/Los_Angeles, US/Pacific
disconnect_for_nonpay
A Boolean value to indicate whether to stop providing service to a service point due to the customer not paying bills.
Can Be Empty?: Yes.
