2 Accessing the Opower Configuration Tool
You can access the Opower Configuration Tool at https://configuration.opower.com/ and log in using the credentials provided to you by Oracle Utilities. After logging in to the Opower Configuration Tool, the system displays the Home page, which provides a navigation panel you can use to access the configuration tools, and high-level steps to configure and publish modifications to your web portal. You can use each of the following Opower Configuration Tool categories to complete the tasks to configure your products:
- Pages: The pages of your environment create the structure of your Digital Self Service - Transactions web portal and determine where widgets are included. For more information, see Configuring Pages and Including Widgets
- Widgets: Widgets are components of Digital Self Service - Transactions that provide the features and functionality that customers interact with on the web portal. For more information on configuring widgets, including feature behavior and message properties, see Configuring Widgets.
- Publish: When configurations are complete and ready for testing, the workspace that acts as a container of those changes can be saved as a version and then promoted through the various environments available to you. The final production environment applies and publishes those configurations to the user base of your web portal. For more information, see Publishing Configurations.
- Settings: Settings within the Opower Configuration Tool include configuration of product versions and various global configurations for your products. For more information, see Defining Global Styling and Configurations.
For best practices on using Opower Configuration Tool to complete your product configuration, see Best Practices and Configuration Considerations.
