Utility Branding Inputs
The configuration options listed in the table below apply to the utility's branding. They are used to configure the appearance of Oracle Utilities Opower products to match the utility's branding guidelines. For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Note: Oracle Utilities requires multiple branding files from the utility, such as the utility logo and the utility branding guidelines. Provide all files listed in this table as an email attachment to your Service Delivery Manager along with the completed version of this form. See Next Steps for more information.
Configuration Option | Input Value |
Utility Logo
The RGB and CMYK versions of the utility logo as .ai files. Example: UtilityCo_Logo_RGB.ai |
Required File name of RGB utility logo:
File name of CMYK utility logo:
Utility Branding Guidelines The branding guidelines are used to help designers from Oracle Utilities develop creative elements throughout the program life cycle. Indicate the PDF file name of the utility branding guidelines or visual style guide. Example: UtilityCo_Branding_Guidelines.pdf |
Required |
Utility Color Palette To ensure that Oracle Utilities uses the correct colors for the utility's brand, indicate the PDF file names of the RGB and CMYK color palettes. Example: UtilityCo_ColorPalette_RGB.pdf |
Required RGB color palette:
CMYK color palette:
Sample Bill Indicate the PDF file name of a sample customer-facing energy bill. Oracle Utilities uses the sample bill to help ensure that our products align with the utility's branding. Example: UtilityCo_Sample_Bill.pdf |
Required |
Account Number Format An example of how the customer account number is formatted on the bill. In your example, indicate how many digits should be displayed (in the example below, four digits are displayed). Example: 12-34XX-XXX |
Required |
