2 Getting Started
This guide is used during the Oracle Utilities Opower launch process to provide product design information, collect utility configuration preferences for the products being launched, and track the finalization of these preferences. The preferences are then used to set up your Oracle Utilities Opower products and platform. This guide is focused on the global configuration options that apply to all products on the platform. It should be completed along with all other product-specific configuration guides provided to you when you Contact Your Delivery Team.
This HTML documentation is for reference only. Your Delivery Team will give you an editable PDF or DOCX version of the document to capture your inputs. Once submitted to Oracle Utilities, all utility inputs recorded in the configuration guides are final and cannot be modified. Ensure that all configuration inputs are accurate before submitting them.
Product Overview
The Oracle Utilities Opower platform refers to components that apply to multiple Oracle Utilities Opower products. For example, such components include global branding elements, energy efficiency details related to a utility territory, applicable rate codes, and so on.
Disclaimer
Your utility might not have all of the products or features described in this document. Contact Your Delivery Team if you have any questions.
