Text Alerts
SMS High Bill Alerts AMI are text messages sent through the mobile channel to inform customers when they are on track for a high bill or high energy use. SMS alerts are only delivered if the SMS alert type is turned on in a customer's account settings, and if the customer meets the minimum eligibility criteria to receive the SMS alert type. A dual fuel customer, which includes customers that receive electricity along with either gas or water, receives a single, combined fuel text message.
Design
The following image shows an example of a High Bill Alert AMI text message.
This image shows an example of the text alert.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Utility Name
Both the name itself and the name length are configurable up to 45 characters. Four characters or less is recommended.
Note: SMS scripts are designed with character number requirements (160 maximum) in mind to ensure that they fit within a single message. It is strongly recommended that a short utility name of four characters or less is used to ensure that alerts stay within a single message.
Required
Provide the utility name to include in text alerts.
Opt-Out Message or Tip
Due to space limitations, an opt-out message and a tip cannot be included in the text message at the same time.
Default: Do not include opt-out message.
Required
Choose one of the following:
Do not include an opt-out message. (Default)
Include an opt-out message.
Enable Forecast Range
Specify whether the projected amount is displayed as a range rather than as a specific amount.
Default: Display a single amount
Optional
Choose one of these options:
Display single amount. (Default)
Display a range.
Include Account Number
Specify whether to include the account number in the text message. The number of characters that are displayed in the message is determined by the configuration setting used to mask characters in the High Bill Alert AMI Email.
If including the account number, it might be necessary to alter the text in the message to conform to the recommended 160 character limit.
Default: Do not include the account number.
Optional
Do not include the account number. (Default)
Include the account number.
User Experience Variations
This text shows an example of a High Bill Alert AMI SMS message:
UTILCO: Your energy use may be 38% higher than usual & above your alert threshold Up to 4msg/mo Msg&Data rates may apply Reply STOP to optout or HELP for info
The following example text is for a customer without rates modeled or who is on budget billing:
UTILCO: Your electricity use may be 15% higher than usual & above your alert threshold.
The following example text is for a customer whose rate plan has been modeled by Oracle Utilities. In this case, a dollar amount is used instead of a percentage:
UTILCO: Based on your electricity use, your next bill may be $100.00 & above your alert threshold.
