Water Time of Day Module
The Water Time of Day module identifies the time of day in which the customer tends to use the most water and expresses this as a percentage, so that the customer knows when to focus on being more energy-efficient. The usage value represents usage-to-date within the current bill period. The six-hour time period with the most usage is highlighted, while the other three time periods display in a faded color.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Options | Input Value |
Heading You can update the heading of the module as needed. Default: "When you use the most water". |
Optional Choose one of the following:
Insight Statement You can update the insight statement if needed. Default: "Think about what's using the most water in the <period name>." |
Period Names in Chart You can name each of the time periods in the chart. Defaults:
See More Water Trends Button You can update the text on this button, as well as the URL to which the customer is directed when clicking the button. Default: "See More Water Trends" You must also specify the URL the customer should link to when clicking the button. |
Required Choose one of the following:
User Experience Variations
This section describes the user experience variations in the Water Time of Day module.
Multiple High-Use Periods (Tie State)
Customers can have a tie with regard to which time period uses the most water. This module varies based on whether there are 1, 2, 3, or 4 periods with the same highest usage. The module highlights all periods that tie for the highest usage, and the insight statement varies as follows:
- Two-way tie: Think about what's using water in the <period1> and <period2>.
- Three-way tie: Think about what's using water in the <period1>, <period2>, and <period3>.
- All periods use the same: You are using an equal amount of water throughout the day.
