Personalized Tips Module
The Personalized Tips module provides customers with tips on how to reduce their energy use and bills based upon how the customer uses energy.
Design
This image shows an example of the module:
This image shows an example of the module.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Tip Content
The content of each tip focuses on an action that customers can take to reduce energy use, and how much customers can save by doing the action.
Default: Varies by tip.
Required
Contact Your Delivery Team to discuss which tips and content to include in your program.
If the Oracle Utilities Opower Home Energy Reports are part of your program, you should talk to your Delivery Team about reviewing your tip library.
Number of Tips
The number of tips to display as part of the module, which can range from one to three tips.
Default: Three tips
Optional
Provide the number of tips to display, which can be one, two, or three tips.
See More Ways to Save Button
If available, the button directs users to the Digital Self Service - Energy Management Ways to Save, where customers can see the public-facing version of this page even if they have not signed in.
Alternatively, you can configure this button to direct customers to an alternate page, or you can remove the button.
Optional
Choose one of the following:
  • Do not include the button.
  • Use the following URL for the button:
