Easy Open Module
The Easy Open module enables customers to easily access the Home Energy Analysis feature from their email communication without needing to sign in to their utility account. Removing this sign-in barrier increases engagement and customer satisfaction, and improves product functionality and the overall customer experience.
Design
This image shows an example of the Easy Open module:
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Options | Input Value |
Heading The heading of the module can be customized to meet the needs of the utility. Default: Get personalized tips for your home |
Optional Choose one of the following:
Home Energy Analysis Statement The statement about the Home Energy Analysis can be customized to meet the needs of the utility. Default: Whether you live in a single-family home, and apartment, or a condo, there are plenty of ways to save that you may not know about. With our Home Energy Audit, you can answer a few questions to see where you're using the most energy, and find tips to help you start saving right away. |
Start The Survey Button You can update the text on this button, as well as the URL to which the customer is directed when clicking the button. Default: START THE SURVEY You must also specify the URL the customer should link to when clicking the button. |
Required Choose one of the following:
