Overpayments On Loans
You can determine whether you want to accept loan overpayments. Overpayments reduce the principal amount (the amount owed on the loan), which follows the philosophy adopted by a typical home loan.
When the payment is made, any overpayments are distributed according to the overpayment distribution algorithm defined for the customer class. Any customer classes for which you want to allow loan overpayments should use an overpayment distribution algorithm that keeps the overpayment on the loan SA.
When the payment transaction is frozen, the system checks to see if there is a credit amount on the loan SA's current balance. If a credit exists, the customer has made an overpayment and an adjustment is created to zero out the current balance and transfer the amount of the credit from the SA's short-term receivable to long-term receivable. The adjustment may appear on the customer's next bill to show the additional amount paid against the principal.
The algorithm that controls this adjustment to remove the credit on current balance is plugged in on the loan service agreement's SA type and is applied on the SA Type - Payment Freeze system event.
The third and fourth entries in the following table illustrate an overpayment (note, the first two financial transactions were described above).
Event
GL Accounting
Effect On Current Balance
Effect On Payoff Balance
Current Balance
Payoff Balance
Loan service agreement is activated
Long Term Loan Receivable 10000
Cash <10000>
0
10,000
0
10,000
long-term: 10,000
First bill segment is produced
Interest:
Long Term Loan Receivable 41.66
Interest Revenue <41.66>
Transfer Long Term To Short Term:
Short Term Loan Receivable 438.71
Long Term Loan Receivable <438.71>
438.71
41.66
438.71
10,041.66
short-term: 438.71
long-term: 9,602.95
Payment is made (with an overpayment of 200.00)
Affect Cash
Cash 638.71
Long Term Loan Receivable <638.71>
Long Term Loan Receivable 638.71
Short Term Loan Receivable <638.71>
-638.71
-638.71
-200.00
9,402.95
short-term: <200.00>
long-term: 9,602.95
Create adjustment to remove SA's credit.
Transfer Short Term Credit to Long Term:
Short Term Loan Receivable 200.00
Long Term Loan Receivable <200.00>
200.00
0
0
9,402.95
short-term: 0
long-term: 9,402.95
In the third financial transaction illustrated above, the billed amount of the payment works essentially the same as that illustrated under Paying What Is Owed. If the Keep Overpayment on Loan SA algorithm is plugged in on the overpayment distribution event on the customer class, the overpayment amount is applied to the loan SA, creating a credit on the SA's current balance. The following explains how this algorithm works:
• If the account has an loan SA and there is an excess credit, the credit is applied to the loan SA (as long as this does not cause the loan SA to have a credit payoff balance).
• If there is not a loan SA to which the credit can be applied, the algorithm checks to see if there is an open excess credit SA for the account.
◦ If so, the excess credit amount is applied to the excess credit SA.
◦ If not, the algorithm creates an excess credit SA and applies the amount to this SA.
The fourth financial transaction illustrated above is created if the Create Adjustment to Remove SA's Credit algorithm is plugged in on the loan's SA type's payment freeze event. The following explains how this algorithm works:
• If the SA's current balance is less than zero, the algorithm creates a frozen adjustment that removes the credit by transferring the credit from the short-term receivable to the long-term receivable. This adjustment ID is captured on the pay segment so the adjustment can be canceled if the payment is later canceled. Note that the adjustment cancel reason used by the system in this case is specified on the Financial Transaction Options Feature Configuration using the Adjustment Cancel Reason For Payment Linked To Adjustment option type.
• The SA's current balance increases by the amount of the credit transfer. In other words, the customer thinks they owe 0 after the transfer.
• The SA's payoff balance doesn't change because the payoff balance is always the net of the short-term and long-term receivables. In other words, if the customer wanted to payoff their loan, they'd still owe 9,402.95.
Overpayments and interest. The base package interest calculation algorithm (plugged in on the loan's SA type) does not take into consideration the exact date that the overpayment is made when calculating the interest for the period. It only takes into consideration the outstanding principal amount (payoff balance - current balance) at the time of the interest calculation.
