Rate
In order to generate separate calculation lines for the revenue and tax breakdown of the prepaid amount, you need to set up a prepaid rate with components that calculate revenue amount and tax amount given just a total amount.
Create a rate schedule with the following components:
• Tax Calculation Rule
◦ Calculation Rule Type = Calculation Algorithm
◦ Value Type = Percentage
◦ Value Source = Bill Factor
◦ Bill Factor = your tax bill factor
◦ Calculation Algorithm = the one created for algorithm type C1-PCTGVNTOT. Refer to Calculation Rule - Calculation Algorithm for information.
◦ Distribution Code = your distribution code for tax liability
• Revenue Calculation Rule
◦ Derive SQ = checked
◦ Value Type = Unit Charge
◦ Bill Factor = your rate/kWh bill factor
◦ UOM/TOD/SQI to use for the resulting calculated usage, for example kWh
◦ RC Cross Reference = indicate the sequence for the tax calculation rule (above)
◦ Calculation Algorithm = the one created for algorithm type C1-BACKINREV. Refer to Calculation Rule - Calculation Algorithm for information.
◦ Distribution Code = your distribution code for revenue
