Adding Rebate Definitions
Use the following procedure to add a rebate definition:
• Click Add in the title bar of the Rebate Definition zone.
• Enter a Description of the rebate definition.
• Select the Product for the rebate definition from the dropdown list.
• Select the Service Type for the rebate definition from the dropdown list.
• Enter the Rebate Per Unit Amount for the rebate definition.
• Enter the Rebate Unit of Measure for the rebate definition.
• Select the Expense Adjustment Type for the rebate definition from the dropdown list.
• Enter the Presumed Energy Savings for the rebate definition.
• Select the Presumed Energy Savings Unit of Measure for the rebate definition from the dropdown list.
• Enter the Manufacturer and Model for each item eligible to be submitted as a rebate claim line.
• To upload manufacturer/model information from a comma-separated-values file, click CSV File to Upload.
◦ Click Browse on the File Upload dialog, and browse to the file to be uploaded.
◦ Click Upload.
• Click Save. To return to the Rebate Definition zone without adding the rebate definition, click Cancel.
