Bill Suggestions
Most companies have found it impossible to load bill segment item, bill calculation header and lines with sufficient information and therefore these tables are not populated. See the comments in the above ERD's for more information.
Please populate the columns on the FT that's associated with the bill segment as follows:
• CUR_​AMT should be set equal to the bill segment amount
• PAY_​AMT should be set equal to the bill segment amount
• CRE_​DTTM should be set equal to the bill segment end date / time
• FREEZE_​SW should be "Y"
• FREEZE_​DTTM should be set equal to the bill segment end date / time
• ARS_​DT should be set equal to the bill segment end date
• CORRECTION_​SW should be "N"
• REDUNDANT_​SW should be "N"
• NEW_​DEBIT_​SW should be "N"
• NOT_​IN_​ARS_​SW should be set to "N"
• SHOW_​ON_​BILL_​SW should be set to "N"
• ACCOUNTING_​DT should be set to the current date
• SCHED_​DISTRIB_​DT should be left blank
• CURRENCY_​CD should be the currency on the installation record
• BAL_​CTL_​GRP_​ID should be left blank
• XFERRED_​OUT_​SW should be set to "Y"
• PARENT_​ID should be set to the bill ID
• SIBLING_​ID should be set to the bill segment ID
• Do NOT create any GL details for the FT. If GL details are converted, ensure they are populated with the EXACT information SPL CC&B would use to create them. This information is used to create the reversing GL entry when the bill segment is canceled.
