Bill - Characteristics
The Characteristics page is a grid containing one row for each characteristic linked to the bill. Bill characteristics are purely informational.
You can only choose characteristic types defined as permissible on a bill record. Refer to Setting Up Characteristic Types and Their Values for more information.
Open Menu > Financial > Bill > Search and navigate to the Characteristics page to view this information.
Description of Page
The following fields display on the grid:
• Characteristic Type must be a type of characteristic defined as permissible on a bill record.
• Sequence Controls the order in which characteristics of the same type are displayed.
• Characteristic Value indicates the value of the characteristic if the characteristic type is pre-defined or foreign key reference.
