A Package With More Complex Operators
One of the eligibility groups described under
Criteria Groups versus Eligibility Criteria has the following eligibility rules:
• Customer must live in California
• Service provider is A, B or C
The eligibility group in which these rules would be defined looks as follows:
| Group No. | Group Description | If Group is TRUE | If Group is FALSE |
| 1 | Lives in California, current service provider is either retailer A, B or C | Eligible | Ineligible |
The following criteria will be required for this group:
| Group 1: Lives in California, current service provider is either retailer A, B or C |
| Seq | Field to Compare | Comparison Method | If TRUE | If FALSE | If Insufficient Data |
| 10 | Algorithm: retrieve order's state | = CA | Check next condition | Group is false | Group is false |
| 20 | Misc Field On Order: Current electric supplier | IN A, B, C | Group is true | Group is false | Group is false |
This example is very simple. The only thing worth pointing out is that a number of operators can be used when you define a "comparison method". Refer to
Package - Eligibility for the complete list of operators.
Parent topic
