A Calculation Rule with a Discount for Being on Autopay
Imagine a calculation rule that is only eligible if the current customer has signed up for Autopay. This calculation rule would need the following eligibility rule:
• Customer has Autopay
This rule will look as follows:
Seq
Field to Compare
Comparison Method
If TRUE
If FALSE
If Insufficient Data
10
Algorithm: check if customer has Autopay
= Y
Apply Rule
Do Not Apply Rule
Do Not Apply Rule
The criterion calls an algorithm that performs a logical comparison.
The criterion works as follows:
• Field to Compare. We chose a "field to compare" algorithm that checks if the account associated with the bill segment is on Autopay. If an autopay setup exists, then it returns a value of Y. If not, however, it returns N
• Comparison Method and Results. We simply compare the value returned by the algorithm to Y and indicate the appropriate response. If the condition is true, the calculation rule is applied. If the condition is false or insufficient data, the calculation rule is skipped.
Refer to CI_​CHK_​APAY for more information about this algorithm.
