Understanding Data Sources
Data Sources define the source of data to be aggregated, such as measurement data from usage subscriptions linked to a service point, badged or unbadged items, or measuring component sets. Data sources also define configurations used when generating dynamic queries used by aggregation processing.
Data Source Classes
Data sources are defined by classes, each of which is based on a specific business object, and determines the type of configuration used by aggregation processing. More specifically, the data types configured on the data source are used when generating dynamic queries used by aggregation processing.
The table below lists the data source classes and the business object and configuration options for each. Consult the embedded help for more information about the specific configuration options used by each data source class.
Data Source Class
Usage
Business Object
Configuration Options
Measurements from US Service Points
Used when aggregating data from measuring components linked to service points via a usage subscription.
D1-DataSourceMeasurements
Measuring Component Types
Badged Items
Used when aggregating data from badged items.
D1-BadgedItemsDataSource
Item Types
Billed Service Quantities
Used when aggregating data based on billed services quantities.
D1-DataSourceBilledSerQuantity
Usage Subscription Types
Measuring Component Sets
Used when aggregating data from measuring component sets. Data sources of this class are used with composite aggregation.
D1-DataSourceMCSet
Unbadged Items
Used when aggregating data from unbadged items.
D1-DataSourceUnbadgedItems
Item Types
Measurements from US Direct Links
Used when aggregating data from measuring components directly linked to a usage subscription.
D1-DataSourceMeasurementDirect
Service Point Quantities
Used when aggregating data based on service point quantities.
D1-DataSourceSPQuantities
Service Point Quantity Types
Attribute and Measurement Data Snapshot
Used when aggregating data based on data snapshots
D1-MasterAndMsrmtDataSnapshot
Measurement Data Snapshot Types
Data Source Template SQL
Data sources also provide template structured query language (SQL) used when generating dynamic queries used by aggregation processing. This template SQL is used as the basis for dynamic queries, and is extended by additional SQL generated from the data source configuration as well as configuration defined for measuring component sets, measuring components, and measuring component types that reference the data source. Template SQL is provided via the Data Source SQL (D1-DataSourceSQLLookup) extendable lookup. Values for this extendable lookup are used as the Option Value for the following business object options on the data source business object.
• Dimension Scanner SQL: The template SQL used when dimension scanning. This SQL is extended by the criteria, dimensions, and individually managed items configured on the measuring component sets being processed.
• Find Constituents SQL: The template SQL used when finding constituents. This SQL is extended by attributes defined on the aggregator measuring components being processed.
• Aggregation SQL: The template SQL used when performing aggregation. This SQL is extended by the value identifiers defined on the measuring component type of the aggregator measuring components being processed.
