Configuring Timeliness and Quality Aggregation for Use with Oracle Utilities Analytics Visualization
This topic outlines the configuration needed for timeliness and quality aggregations used with Oracle Utilities Analytics Visualization.
Master Configuration
Create a Timeliness Master Configuration, defining the following:
• Heating Degree Days Factor: A number-based factor that contains heating degree days. These are aggregated and stored on the Measurement Measured Quantity Aggregator.
• Cooling Degree Days Factor: A number-based factor that contains cooling degree days. These are aggregated and stored on the Measurement Measured Quantity Aggregator.
• Number of Hours to Consider IMD as Late: The number of hours after which an initial measurement is considered late.
• Buckets: Value Identifiers that specify the late buckets used by the Measurement Timeliness Count and Measurement Timeliness Quantity aggregators.
Extendable Lookup: BI Aggregation — Usage Group Mapping
If your implementation makes use of dynamic usage calculation group determination on usage subscriptions (via the Calculation Group Determination Override Algorithm on the usage subscription type, the Rate History collection on the usage subscription, and the CCB Rate Schedule extendable lookup (D2-CCBRateScheduleLookup)), you will need to configure the BI Aggregation Usage Group Mapping extendable lookup (D2-UsageCalculationGroupLookup) with the usage calculation groups you wish to aggregate. If in the future you add new usage calculation groups, you will also need to add those usage calculation groups to this extendable lookup if you want them to be aggregated.
Note that an aggregation measuring component will be created for all dimension combinations and each usage calculation group in the extendable lookup (this is done to alleviate the need to execute the usage group determination algorithm for all usage subscriptions during the dimension scanning process).
Configuring this extendable lookup is required ONLY if using dynamic usage calculation group determination.
Measuring Component Types
Create a master aggregator measuring component type and sub aggregator measuring component types for the four types of aggregators outlined above. Details for each aggregator measuring component type are listed below.
• Measuring Component Type Business Object: Master Measurement Aggregator Type (D2-MasterMsrmtAggregatorType)
• Measuring Component Business Object: Measurement Measured Quantity Aggregator (D2-MeasuredQuantityAggregator)
• Measurement Business Object: Measured Quantity Measurement (D2-MeasuredQuantityMsrmt)
• Value Identifiers (recommended):
Value Identifier Type
Description
Unit of Measure
Measurement
kWh
Kilowatt-Hours
Value 01
Regular kWh
Kilowatt-Hours
Value 02
Estimated kWh
Kilowatt-Hours
Value 03
User-Edited kWh
Kilowatt-Hours
Value 06
Count
Count
Value 07
Heating Degree
Fahrenheit
Value 08
Cooling Degree
Fahrenheit
Value 09
Ave kWh
Kilowatt-Hours
• Sub Aggregator MC Types (see below):
◦ Measurement Quality Count Aggregator Type
◦ Measurement Timeliness Count Aggregator Type
◦ Measurement Timeliness Quantity Aggregator Type
• Measuring Component Type Business Object: Sub Measurement Aggregator Type (D2-SubMeasurementAggType)
• Measuring Component Business Object: Measurement Quality Count Aggregator (D2-MsrmtQualityCountAggregator)
• Measurement Business Object: Quality Count Measurement (D2-QualityCountMsrmt)
Description
Unit of Measure
Measurement
kWh
Kilowatt-Hours
Value 01
Regular Count
Count
Value 02
Estimated Count
Count
Value 03
User-Edited Count
Count
Value 04
N Meas/No IMD Count
Count
Value 05
No Meas/IMD Exists Count
Count
Value 06
Read Outage Count
Count
Value 07
Read Other Count
Count
Value 08
Missing Count
Count
• Measuring Component Business Object: Measurement Timeliness Count Aggregator (D2-MsrmtTimelinessCountAggr)
• Measurement Business Object: Timeliness Count Measurement (D2-TimelinessCountMsrmt)
Description
Unit of Measure
Measurement
kWh
Kilowatt-Hours
Value 01
On Time Count
Count
Value 02
Late Count
Count
Value 03
Very Late Count
Count
Value 04
Very, Very Late Count
Count
Value 05
Missing Count
Count
• Measuring Component Type Business Object: Sub Measurement Aggregator Type(D2-SubMeasurementAggType)
• Measuring Component Business Object: Measurement Timeliness Quantity Aggregator (D2-MsrmtTimelinessQuantityAggr)
• Measurement Business Object: Timeliness Quantity Measurement (D2-TimelinessQuantityMsrmt)
Description
Unit of Measure
Measurement
kWh
Kilowatt-Hours
Value 01
On Time kWh
Kilowatt-Hours
Value 02
Late kWh
Kilowatt-Hours
Value 03
Very Late kWh
Kilowatt-Hours
Value 04
Very, Very Late kWh
Kilowatt-Hours
Activity Type
Create a Measurement Quantity Scanner activity type, based on the following business objects:
• Business Object: Measurement Quantity Scanner Type
• Related Transaction Business Object: Measurement Quantity Scanner
