Master Configurations
Master configurations define configuration settings for individual adapters. The sections below provide details for the master configuration provided for each Smart Grid Gateway adapter.
Itron OpenWay Master Configuration
The “Itron – Master Config” master configuration defines details used by the Itron OpenWay commands and payload processing, including the following:
• Command Status Changed URL Configuration: Used to define URL configuration for asynchronous callback requests.
◦ Status Changed Service URL Script: Used to define a service script which composes the URL for asynchronous callbacks. The script should include an /output/applicationUrl field containing the results. When determining the URL, the system initially checks if a script has been configured on this field, and if so, that script is used. If this field is blank (which is the default), the Determine Application URL (D1-DetStChSU) script is used to compose the URL.
◦ Default Status Changed Service URL: The base portion of a URL sent to the head end system which provides a location to which it should send an asynchronous callback request. This base URL is appended by command-specific URL components defined as algorithm parameters on "Populate Send Details." algorithms on outbound communication business objects.
◦ Commands: Command-specific base URLs for asynchronous callback requests
• Arrived Data Save Locations: Used to define how payloads and exceptions are routed and processed by the Itron DataSubscriberService, Itron EventSubscriberService, and Itron ExceptionSubscriberService inbound web services.
◦ DataArrived Output Configuration: Defines how payloads are routed and processed by the Itron DataSubscriberService inbound web service.
▪ File Storage: The location where payloads are routed in the event of an error when processing the payload. This should be a File Location Extendable Lookup value.
▪ Error Output Location: The specific bucket or folder within the file storage location where payloads with errors are routed.
▪ Processing Configuration Value: A SGG Payload Processing Configuration extendable lookup used to define parameters for processing Itron OpenWay payloads.
◦ EventsArrived Output Configuration: Defines how event payloads are routed and processed by the Itron EventSubscriberService inbound web service.
▪ File Storage: The location where event payloads are routed in the event of an error when processing the payload. This should be a File Location Extendable Lookup value.
▪ Error Output Location: The specific bucket or folder within the file storage location where event payloads with errors are routed
▪ Processing Configuration Value: A SGG Payload Processing Configuration extendable lookup used to define parameters for processing Itron OpenWay event payloads
◦ ExceptionsArrived Output Configuration: Defines how exceptions are routed and processed by the Itron ExceptionSubscriberService inbound web service
▪ File Storage: The location where exceptions are routed in the event of an error when processing the exception. This should be a File Location Extendable Lookup value
▪ Error Output Location: The specific bucket or folder within the file storage location exceptions with errors are routed
▪ Processing Configuration Value: An SGG Payload Processing Configuration extendable lookup used to define parameters for processing Itron OpenWay exceptions
Landis+Gyr Master Configuration
The “L+G – Master Config” master configuration defines details used by the Landis+Gyr commands and payload processing, including the following:
• AMI Events Configuration: Used to define settings for the CIM AMIEvent interface
◦ Save to Staging Area: Flag that indicate whether to save incoming data to a staging area, such as Oracle Object Storage, or process it directly
◦ Processing Configuration Value: An SGG Payload Processing Configuration extendable lookup used when immediately processing the AMIEvent payloads
Sensus Master Configuration
The “Sensus Master Configuration” master configuration defines details used by the Sensus commands and outage events, including the following:
• Outage Events Head End System: Used to define the head end system expected to which outage events are sent via the ODEventNotification interface
Silver Spring Networks Version Master Configuration
The “SSN – Version Master Config” master configuration specifies the version of the Silver Spring Networks head end system with which the system is communicating:
• SSN Version: Used to define the version of the Silver Spring Networks head end system. Options include:
◦ SSN Version 4.4
◦ SSN Version 4.7
◦ SSN Version 4.10
SSN Version 4.10 is only version of the Silver Spring Networks adapter supported with native implementations.
• SSN - Get Job Status Configuration: Used to specify the Retry Limit and Wait Duration (in Seconds) for the Get Job Status requests sent by outbound communications.
