High/Low Check
This validation rule compares the total consumption of the current IMD to historical values. The comparison is normalized based on average daily usage (ADU). If the current IMD is too high or too low compared to historical data then an exception is thrown.
Numerous configuration options are provided including:
• A Historical Pre-Window and Post-Window that determines the number of days to check before and after the period being examined.
• Percentages to control how much of the historical data can be user edited, estimated, or non-normal data.
• What type of historical data to look at first
• What to do when an outage has occurred
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-HILO-CHK Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-VEERuleHighLowCheck
