Maintaining Install Events
This portal is used to display and maintain install events.
You can access the portal from Menu > Device Installation > Install Event. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Install Event: defines the basic attributes of the Install Event, the on/off history for the Install Event, and removal information.
When creating a new record, the following options are available:
Name
Details
Business Object
Communication Component Install Event
This Install Event is intended for use with a Communication Component that is installed on top of a traditional Meter.
D1-CommComponentInstallEvent
Item Installation Event
This Install Event records the installation of an Item (i.e. streetlight).
D1-ItemInstallEvent
Manual Meter Installation Event
This Install Event is used for manually read meters.
D1-ManualMeterInstallEvent
Smart Meter Installation Event
This Install Event is unique to smart meters and has a lifecycle that's maintained by remote meter commands.
D1-SmartMeterInstallEvent
In Oracle Utilities Customer To Meter, when a device with a related asset is installed at a service point, the install event updates the asset’s disposition, changing its Status and Asset Disposition to “Installed” and its Location to the service point with an effective date matching the install event’s Installation Date/Time.
